  • Dot Guests: 934
Author Topic: Master cylinder  (Read 5042 times)
Offline Postie Bob
Master cylinder
« on: December 11, 2012, 08:45:47 PM »
G`day all.
The bottom lug on my master cylinder is broken off.
Is there a replacement cylinder available that I can use without much drama ?
The original one needs an overhaul anyway and I can,t for the life of me work out how it comes apart!!!
Could the lug be welded back on successfully ( it,s cast iron ) or is that a no-no .
Any assist much appreciated .
Cheers , Bob.
Offline Postie Bob
Re: Master cylinder
« Reply #1 on: December 16, 2012, 04:44:21 PM »
Still scratching my head over this master cylinder  :-[ .
Mine is a Lockheed 3211/832c model .
Are they serviceable ?  What is holding it all together ?
Do I keep looking for a suitable replacement ?
Cheers, Bob.
Re: Master cylinder
« Reply #2 on: December 16, 2012, 05:49:20 PM »
from memory i think you need to unbolt the resevior an theres a pin in the port or the bolt  holds the plunger in   i fink !!! ;D ;D ??? ???
Re: Master cylinder
« Reply #3 on: December 16, 2012, 06:58:05 PM »
Try to source anoyher standard one Mine cost $220.00 to have rebuilt with ss sleeve Works perfect with 4wheel discs Check out my gallery photos all there Cheers Reid
