  • Dot Guests: 1254
Author Topic: Cresta diff conversion?  (Read 27738 times)
Re: Cresta diff conversion?
« Reply #10 on: October 24, 2008, 09:38:30 PM »
I've got one of these conversions in mine and when I ran the 186 with trimatic it still used to rev pretty high at 100k.
See, told you so!
« Reply #11 on: October 25, 2008, 08:37:46 PM »
hey chris. you said early model diff..
so would i be right in guessing that the early diff had 9 inch drums and the later model diff had 10 inch drums? or is the 10inch drum diff just a special that came with some?
most of the diffs i see have 9 inch drums
but i own 3 10 inch drum diffs now just after saying that..
« Reply #12 on: January 09, 2010, 12:46:33 PM »
This works only with the SWB as those models have the fine splines. The LWB has coarser splines, and is a different diff.
I was very happy with my first Beddy which I put one in with a slant Valient motor.
My current van has one also, and with the LD28 is about right.
« Last Edit: January 09, 2010, 12:54:13 PM by Jeff »
« Reply #13 on: January 10, 2010, 05:28:58 PM »
Hay Rogue, you have to use the drive head from an auto only as they are 3.5, Man- is 4.1, so no good. I changed my over myself, placed it in the vice and greased the crown wheel, and turned it until you got any even patten transfering on to the pinion, 5 years later still good.
« Reply #14 on: January 10, 2010, 05:44:05 PM »
I didn't actually do the conversion myself. I swapped the diff with another club member many many moons ago. I think the problem was more that I was comparing it with the car which is a 5 speed manual whereas the van at the time was running the 3 speed traumatic. It was definitely better than the original diff.
I am so looking forward to running a 4 speed auto behind the V6 with a 3.07 ratio.
Offline waikatostocky
« Reply #15 on: January 12, 2010, 01:33:57 AM »
'ben mate all the 9" drums must of gone to Oz then i got a creasta conversion done on a 9" drum housing and now i carnt find any drums to go on it dam hate that lol. ::)
cheers Paddy
be safe out there
« Reply #16 on: January 12, 2010, 04:17:43 AM »
The original diff in mine was the 10" however the Cresta conversion came on a 9". Keep an eye out at the wreckers. We've had quite a few CF's through Pick-A-Part down here over the last couple of months.
« Reply #17 on: January 12, 2010, 04:35:10 PM »
have been droping into quit a few yards i know a few of the lads in wreakers up this way from when i was raceing the stockcar.
havent had much luck yet lol.
Cheers Paddy
be safe out there
« Reply #18 on: January 12, 2010, 06:24:37 PM »
There's one on TradeMe . A bit pricey @ $400 buy now.
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Other/auction-264288506.htm
Hey Paddy, Can't you fit 10" brakes to it?
« Last Edit: January 12, 2010, 06:45:28 PM by Jeff »
Offline cfjeff
« Reply #19 on: January 12, 2010, 08:15:29 PM »
Paddy are you looking for 9" cf rear drums, if so I should have plenty in my diff and gearbox shed. If you like I will have a look tomorrow. Just to be clear we are talking about the same thing the 9" brake diffs have 4 bolt backing plate and the 10" 6 bolt backing plate?
 When I recently rebuilt my diff and needed to replace the crown wheel and pinion as mine was too worn. I found a diff on the west coast, the only problem was I had 10" brakes on my diff and the diff I purchased had 9". So I pulled the guts out and swapped the interiors. I still have all the left over parts in my shed. Only prob is I'm in christchurch.
Let me know if I can be of help,
Cheers Jeff
Just customize it!
