  • Dot Guests: 1760
Author Topic: door handle ideas needed  (Read 11258 times)
Re: door handle ideas needed
« Reply #10 on: November 22, 2012, 09:49:33 PM »
I like the MX7 ones, but also earlier model XTRAIL ones as well
Offline Bullstik
« Reply #11 on: November 22, 2012, 10:39:55 PM »
what about the carpenters special
http://www.flickr.com/photos/wetcoastlife/7761553628/
why does everyone want them hidden ???
Offline tiwaz_nz
« Reply #12 on: November 23, 2012, 07:24:49 PM »
i like look of the  Renault 5 ones  ;D
Offline outriding
« Reply #13 on: November 24, 2012, 07:23:27 AM »
I like the shaved look but then you got to use door poppers and remotes.. not the most practical solution.
« Reply #14 on: November 29, 2012, 08:17:02 AM »
Thanks for the ideas guys, lada and something else had the side handle thing too
The other option I've seen around is to just use a key lock in the door (no handle) and the lock itself is pushed in to open and locks to stop it being pushed. Have not seen the system but seen it on a old rod, it must have a cylinder inside or something to stop it being forced.
I actually saw a truck door the other day (think it was from a hino), looked good and slim, and didn't look that big, until i transferred the measurements onto the van door - it was big lol
Maybe just do a Mr Bean - latch and padlock, not paint it and call it a ratrodvan
Offline outriding
« Reply #15 on: December 01, 2012, 06:50:36 AM »
That type of cylinder-push button was used on the first 3-door renault 5's.
It did still have a cut away because you need to grab the door somewhere..
Offline shaginwagin
  • Real Vans are BIG Vans
« Reply #16 on: December 02, 2012, 02:11:45 PM »
Hi all,
 I am using VN handles.  reason is that I got a complete donor V6 for motor and the handles where all there. Relatively easy as I cut the metal around the door handle, the door mechanism off the door and grafted them in the Beddie door and also the catch on the pillar and grafted that in as well.  It makes it easier if you can get the complete door and then everything is there as long as mechanism is ok dosent matter what the panel is like.
Julian
