  • Dot Guests: 448
Author Topic: DUAL WHEEL DIFF UNDER CFS?  (Read 4315 times)
Offline Rotti
« on: October 23, 2012, 06:07:08 PM »
Cant find much about this, may be a very good reason....but Is it possible to fit a dual wheel setup under a cfs van? Also the front stubs etc..? :-\ I reckon there would be a bit of weldiing, mounts & swapping over of rear inner guards..anyone done it? ;)
Offline Rotti
Re: DUAL WHEEL DIFF UNDER CFS?
« Reply #1 on: October 28, 2012, 10:41:19 PM »
anyone? :-[
Its probably a really silly question, I know, but I just reckon it would look pretty damn chunky.... ;)
« Reply #2 on: October 28, 2012, 11:04:28 PM »
its do-able but a lot of work ,the spring hangers need to be moved inboard on thr body the rear OUTER arches need to be cut out for the glass flares ,inner arch is the same ,front should be a bolt in proposition ,the rear bodywork would be challenging as you need to fabricate the inner lip for the flares to mount to but its all doable   cheers merlin
