  • Dot Guests: 374
Custom Badges by BlackBedford
[April 29, 2026, 09:05:15 PM]
Author Topic: Any 308s running  (Read 12231 times)
Re: Any 308s running
« Reply #10 on: October 16, 2008, 06:56:55 PM »
I'm not going to say anything about the chevy/holden thing
*whsipers*
bore a 350 out 30 thou and you got a 355, stroke the 350 and you got a rat 383 engine
*stops whispering*
but if I did I'd go along with whats been said and say chevy is the better deal ;)
« Reply #11 on: October 16, 2008, 07:02:40 PM »
yeah, go chev, u will be happier, chev parts are cheap as 2.
plus the sound and power, priceless.
marty
Tweaker
« Reply #12 on: October 16, 2008, 10:06:27 PM »
Hey Busy!
I just read your quote and pissed me self! ;D...................Owe bugger, now I gotta go change! :-[
Offline shaginwagin
  • Real Vans are BIG Vans
« Reply #13 on: October 16, 2008, 10:29:07 PM »
Hi atk1,
Have got a 253  (out of a HZ red motor) in Alien8, attached to a trimatic, and chev caprice diff, (2.77 ratio). Goes alright when you finally get it wound up.  Its getting a 308 next year and a ford diff, with a better ratio.  The advantage with the 253 or 308 is that it sits on the same engine mounts as the 6 cyl.  Yes I think the chev is a narrower engine but you have to get different engine mounts made and then engineer reports.
Julian
« Last Edit: October 16, 2008, 10:32:39 PM by shaginwagin »
Julian
« Reply #14 on: October 17, 2008, 09:10:58 AM »
I think youll have to get an engineers report for the 308 anyway?
doofhard
« Reply #15 on: October 17, 2008, 10:07:36 PM »
yep
Offline shaginwagin
« Reply #16 on: October 18, 2008, 05:28:19 PM »
Yep you are right have already got engineer report for 253, HQ discs, and different diff.  What I should have said was that you won,t have to get the report on the engine mounts as you don,t have to change them.  My mistake :-[
Julian
Julian
doofhard
« Reply #17 on: October 18, 2008, 06:34:03 PM »
Mounting the engine is the least of your worries, they care alot more about your brakes but with a hq disc brake upgrade as long as it's installed properly should make them happy.  When I engineer my LWB chev I have to engineer engine, brakes, gearbox, diff and hopefully power steering it's going to cost an arm and a leg.
