  • Dot Guests: 444
Author Topic: problem engine  (Read 8776 times)
problem engine
« on: June 01, 2012, 10:15:49 AM »
so heres the delima
500kms ago rattle started developing from engine, only occured when under load.
it has since turned into a bad knocking type rattle, still only pronounced under load but its always there now load or not load so its got progressivly worse.
im grounded at chris ryans at the moment so we have few spare parts on hand which is handy.
heres what ive done to try and fix her to date..
-ive pulled the harmonic balancer off and replaced it. not that.
- pulled the timing cover off and checked out cam gear - nope its a fresh new alliminum one.
- pulled the rocker cover off to see if anythings out of order. well cant see anthing not moving right
it sounds like its coming from the bottom of the engine. doesnt sound like bearing noise altou i guess it could be. chris thinks its not bearings cause the noise doesnt sound metalic.
anyone got any suggestions?
Re: problem engine
« Reply #1 on: June 01, 2012, 11:03:12 AM »
Have you checked the timing ?
big end bearing ?
I got nuffink!
Re: problem engine
« Reply #2 on: June 01, 2012, 12:16:12 PM »
there,s a little man in there with a little hammer trying to get out.
in other words sounds like your just about to drop a big end =they usually come out the side.
drop the sump ant try tightning the bigend cap,
if that dont work change the bigend bearing.
thats if its a bigend witch id nearly bet my fav things.
Re: problem engine
« Reply #3 on: June 01, 2012, 12:58:14 PM »
it sounds like a gudgeon pin or cracked piston to me maybe even a skirk missing off a piston in any case it sounds terminal no amount of bandaids will fix it .its engine swap time.btw :you can test it by pulling off the plug leads one at a time till the knock stops,turn engine off pull one lead off start up if noise still the same turn off replace lead then repeat on next lead till the noise changes/stops .dont try pulling the leads with the motor running unless you want an afro and to fart sparks ;D ;D if you do ,remember photo's lloottss of photo's    Cheers merlin
Re: problem engine
« Reply #4 on: June 01, 2012, 12:58:44 PM »
Sounds like a bearing
Get a big screw driver, place it on the block and the handle to your ear - with engine running, move the screw driver around until you can spot the location, if it is a bearing you'll hear it faintly just under idle.
Just becareful you don't short out the starter or screw driver, any clothing, hair etc doesn't get in the fan
Re: problem engine
« Reply #5 on: June 01, 2012, 04:12:54 PM »
Sounds terminal to me dont worry about fixing it just hunt down a good low milage BLUE vh motor & drop that in Ive just finished mine & it sounds sweet smoother running motor than the old RED When it stops raining I will take it out for testing will let you's know how it goes next week cheers Reid
Offline VanWolf
Re: problem engine
« Reply #6 on: June 01, 2012, 04:20:56 PM »
One from left field and my past. Is it a manual? I had a pressure plate bolt work its way lose and it was hitting/skimming the bellhousing. Sounded like a bearing. Go louder as i revved more. opened the inspection cover and found aluminum shavings.Jackpot!!!!
Mike
Re: problem engine
« Reply #7 on: June 01, 2012, 04:38:19 PM »
I had  a flywheel come loose once.....Sounded a bit like a bearing.
Re: problem engine
« Reply #8 on: June 01, 2012, 07:50:59 PM »
did  you remember to put oil in ben ???  :D
Re: problem engine
« Reply #9 on: June 02, 2012, 10:01:51 PM »
hey guys thanks for the great advice. we gave up and pulled the engine out. took us 14 hours.. last 5 hrs we were working in the rain! but all good now.. we have now driven 800kms on the new engine..
huge thanks to chris ryan and the rest of the family for having us for a couple of days:) and for a new engine:)
