  • Dot Guests: 1423
Author Topic: NSW RTA laws  (Read 17540 times)
Offline Mattty
NSW RTA laws
« on: April 03, 2012, 06:06:03 PM »
Hi i have just bought my first Bedford, a 1978 Cf SWB. Can anyone tell me if it is legal to put in a 308, aor a v6 into the bedford? i live in Newcastle NSW.
Re: NSW RTA laws
« Reply #1 on: April 03, 2012, 06:27:17 PM »
Gettin harder all the time For mine I think it's a waist of time & money Id just do a 202 & hang a turbo on it & spend the money on paint & panel work & do up the inside Just my 2bobs worth
Re: NSW RTA laws
« Reply #2 on: April 03, 2012, 06:59:13 PM »
ahh the fun begins eh Matty...i guess u can do a V8 or V6 conversion..if u got the $$ or know how and find a nice friendly engineer.... ;)
Offline VanWolf
Re: NSW RTA laws
« Reply #3 on: April 04, 2012, 06:53:38 AM »
Matty,
You can fit a 304/308 as long as it complies. You will have to have an engineers cert (approx$1200).
Also you need the following:
Two speed wipers
Collapsible steering column
Depending on engine, unleaded fuel filler pipe and anti pollution gear
Windscreen demister to be fitted
More detail info:
http://www.rta.nsw.gov.au/registration/downloads/vsi/vsi_06_-_guidelines_for_light_vehicle_modifications_nov_2007.pdf
Engineers:
http://www.rta.nsw.gov.au/registration/downloads/bulletin_1_v13_29_03_12.pdf
hope this is of some help
Mike
Re: NSW RTA laws
« Reply #4 on: April 04, 2012, 08:38:36 AM »
The bedford has a collapsible steering column.
A collapsible column is defined as having a knuckle/joint which will sheer on impact. The bedford has one between steering column and steering rack, As well as the rubber joint
A non collapsible column would be one where the column goes directly to the steering box (usually pre 60's)
Also if you register the van as a CF 350 instead of a CF 230 the engine size allowed would be greater.
The 350 models are usually lwb vans but some swb base vans did come out as 350 models, they have a greater tare weight
« Last Edit: April 04, 2012, 08:42:41 AM by BusyKiwi »
Re: NSW RTA laws
« Reply #5 on: April 04, 2012, 08:33:00 PM »
Engineers:
Information Sheet vsi15 is no longer on the list of available documents:
http://www.rta.nsw.gov.au/registration/downloads/vsi/vsi_dl1.html?rlid=infosheets
bulletin_1_v13_29_03_12.pdf is no longer available either.
Finding an Engineer is a task.
Offline Mattty
Re: NSW RTA laws
« Reply #6 on: April 05, 2012, 07:41:19 PM »
Thanks for the advice, keeping the 202 and spending the money on panel and paint is a good idea, i am kean to fit rear seats for the kids. I think i can get it approved through the 4WD places ?.
Re: NSW RTA laws
« Reply #7 on: April 05, 2012, 07:53:08 PM »
Id get it regoed in standard form first then put your extra seats in after who would know
Offline Zeeman
Re: NSW RTA laws
« Reply #8 on: April 05, 2012, 09:42:49 PM »
The first cop that pulled you over.
When fitting extra seats, it's easiest to get rear seats from a late model van or similar. Make sure you get ALL mounting plates/assemblies.
Install it the same way as in the original donor vehicle. The extra seating capacity will be a lot more likely to be approved.
Re: NSW RTA laws
« Reply #9 on: April 05, 2012, 11:42:52 PM »
Arn't you meant to have a opening window with the extra seats?
