  • Dot Guests: 1278
Author Topic: spoiler recognise anyone?  (Read 17575 times)
Re: spoiler recognise anyone?
« Reply #10 on: January 23, 2012, 05:29:05 PM »
I have the opposite problem, can't keep mine warm let alone hot.
Am running the VN V6 radiator, around town it's at running temp (as long as I get a few red lights), get on the motorway and drops to cold. Need to block a bit of the grill off
« Reply #11 on: January 23, 2012, 06:12:19 PM »
YEP , same problem, around town it moves up 1-2 marks, on motorway drops back, but water in raidiator is real hot if I remove the cap after running............
Offline willo
« Reply #12 on: January 24, 2012, 12:14:56 PM »
I wish!!!  the red 202 is hauling 3 ton so it is working pretty hard all the time.  I am using a Speco temp gauge and not the original.  What about you guys?  i checked the water temp with a thermometer and it is accurate. I'm running a triple core holden radiator for the beddie but methinks i need more water capacity too.  I tell ya, fixing the airflow into the radiator and not around it helped heaps.  A bit more water capacity and some more refinement / fiddling with the air flow and it should be spot on.
Neil
« Reply #13 on: January 24, 2012, 07:45:17 PM »
are you kiwis running thermostats?
« Reply #14 on: January 24, 2012, 10:08:17 PM »
 :) off topic  :)
« Reply #15 on: January 25, 2012, 05:43:11 AM »
yep standard 180 degree
back on topic, didn't the old XE model falcons etc have a rear spoiler
« Reply #16 on: January 25, 2012, 06:36:11 AM »
Off topic: It's not an uncommon issue. I remember there was a bit about the V6's running cool on the Justcommodores forum.
On topic: I have no idea what that spoiler fits.
« Reply #17 on: January 25, 2012, 10:20:47 AM »
haahahaha ;D
what spoiler?
« Reply #18 on: January 25, 2012, 02:46:13 PM »
You will find this out personaly soon as well, or maybe a while away yet. ;D
« Reply #19 on: April 06, 2012, 08:54:10 PM »
Back to the spoiler remember those Trans Am fronts? might be the lower apron/spoiler
