  • Dot Guests: 1249
Author Topic: One or two piece tailshaft ??  (Read 15478 times)
Re: One or two piece tailshaft ??
« Reply #10 on: February 05, 2012, 07:55:14 AM »
Hey Gordon, If you're changing you diff center then I'd go with a one piece shaft. I'm running a one piece in my LWB and haven't had any trouble with it in 20+ years. Just get it manufacture properly and well balanced and she should be good.
Haven't got your Nationals entry from yet. Hope you can make it.
Garry.
Garry, my middle bearing has done a sad on me on the Jumbo, how long is your one piece shaft, I thought going one piece on a jumbo would be to long ??? but might not have a choice as a bearing for a Bedford is out I guess umless I go to  a VN 2 piece unt......
« Reply #11 on: February 05, 2012, 10:40:31 AM »
Bas, I bought an original bearing with the rubber surround and the metal outer and mounting bracket from the UK for the standard van, but it wasn't cheap. Worked out to about NZ$150 with the shipping. I wouldn't do it again.
« Reply #12 on: February 05, 2012, 10:42:42 AM »
Where from, that's not to bad a price, is the bearing pressed on ??? Cheers
« Reply #13 on: February 05, 2012, 10:48:13 AM »
Bas, it was from Adrian Bailey in the UK. I've found him very reliable. Answers his emails promptly, keeps you updated and his shipping was pretty quick. His Bedford knowledge is also exceptional. His email address is  adrian@roverland.eu. He has a website too. Google adrian bailey classics I think.
« Reply #14 on: February 05, 2012, 10:50:33 AM »
Bas, yep it presses on to the shaft. All you need to do is seperate the two in the middle by loosening the centre bolt. Best is to loosen the bolt while the shaft is still in so you can get a bit of purchase on it. I learned that the had way :) :)
Offline Jonz_carz
  • probationary
« Reply #15 on: April 28, 2012, 04:13:37 PM »
I'm in Melbourne mate can anyone recommend a tails shaft place here
In trying to find info on my 1973 manual lwb Bedford tail shaft I'm converting it to an auto and want to no if manual tail shaft is the same or where to get one to suit
« Reply #16 on: April 28, 2012, 09:11:14 PM »
should be the same jonz_carz. ive swapped manual to auto before, i think from memory i just reemed out the trany mount slots (on tranz crossmember)cause mounting points were slightly different (i think thats right)
