  • Dot Guests: 397
Author Topic: My dash & lack of interior!  (Read 15712 times)
Re: My dash & lack of interior!
« Reply #10 on: August 22, 2008, 05:19:50 PM »
Was it much work fitting the steering column? Not the electrical, but the mechanical?
Offline Clance
    • My Home Page
« Reply #11 on: August 23, 2008, 07:24:48 AM »
Hi ya all, No it isn't too much trouble fitting the column, they mount up pretty close to standard just had to modify the end mount to the rack and change over the vibration rubber, weld square tube on the end to fit over the standard rack arm. I'll take some pics when the sun is shining to show ya.
in regards to the dash, it's just a standard bedford binical that I took the guts out of, then made up a piece of MDF to fit,cut the holes for gauges n lights, modified the fromea of the original so that it leans back about 20 degrees from standard and the raised it about 25 mm so I could see it all properly through the steering wheel. All the standard dashes have real long bolts holding them in place so there is heaps of thread not being used, whack 6 or more washers under each to achieve the desired position.
« Reply #12 on: August 23, 2008, 09:33:43 AM »
Photos of the column will be great. Thanks
Offline Clance
    • My Home Page
« Reply #13 on: August 27, 2008, 07:57:21 AM »
Hi Guys, Pics of the steering column are now up in my gallery! Have a nice day. :o
« Reply #14 on: September 01, 2008, 09:48:58 PM »
Hey clance what brand are the gauges ??
« Last Edit: September 01, 2008, 09:51:33 PM by Warren »
Offline Clance
    • My Home Page
« Reply #15 on: September 02, 2008, 07:45:23 AM »
Speedo built by Stuart Wagner for S.A. police, fuel gauge by Speco & 4 way gauge by Autoplutonium. Check the links I posted earlier in this thread or search for speedo on the old site for more info.
Clance
« Reply #16 on: September 02, 2008, 10:27:45 AM »
Thanks for the info Clance
I had a look at the links, but I thought the speedo & tacho may have been from the same crowd.
Offline Clance
    • My Home Page
« Reply #17 on: September 03, 2008, 07:59:00 AM »
Nah Sorry Warren there from all over the place hey!1 I can tell you they all took some hunting down! Like trying to get a mechanical speedo with the right cable connection was a nightmare!!
Good Hunting.
Clance
Offline Clance
    • My Home Page
« Reply #18 on: September 11, 2008, 04:06:34 PM »
Hi Guys n Gals,
Just an update on the Beddie! Done heaps of interior work, 2/3rds of the wall and roof lining done, 2/3rds of the lights are in, even hung my favorite painting. Check out my gallery for latest pics!
Have a great day.
Clance
 ;D ;D
