  • Dot Guests: 589
Author Topic: Drive line SOS  (Read 30138 times)
Offline Hippo
  • 1977 CF LWB Motorhome
Re: Drive line SOS
« Reply #40 on: February 10, 2011, 07:10:01 AM »
Noid,
Does the VN diff head fit in the Bedford housing? Or did you already have a VN housing under your Beddy.
Hippo
Re: Drive line SOS
« Reply #41 on: February 10, 2011, 12:01:19 PM »
3:55 is gunna be heaps better for towing busy. i would only tow in 3rd gear all the time. otherwise your likely to blow up your overdrive gear. people say even with the v8 t700 only tow in 3rd ay, not a strong enough box.
Re: Drive line SOS
« Reply #42 on: February 10, 2011, 12:07:14 PM »
hippo, seems as thou the borg wagner only came with 3:45 then jumped to 3:89.
this post may interest you if you havnt already read it
http://www.buga.com.au/index.php?option=com_smf&Itemid=2&topic=1966.10
Offline Noid
  • Living the dream
Re: Drive line SOS
« Reply #43 on: February 10, 2011, 12:39:47 PM »
Mine has a borg wagner in it, I had it widened to suit the Beddy track. When it ran the 186 the ratio was 2.98:1 and worked well with the trimatic but it was to tall for the v6 and th700 with over drive. With the v6 pretty much had to run around in 3RD gear or it would jump in and out of OD all the time.
Busy I don't tow with mine but Ive carried some reasonable loads and it pulled fine. If you have time I would definitely change the ratio before your trip.
Re: Drive line SOS
« Reply #44 on: February 10, 2011, 01:31:52 PM »
out of interest how much did it cost to get centres changed noid?
Re: Drive line SOS
« Reply #45 on: February 10, 2011, 02:31:14 PM »
Ok, to through a spanner in the works, In my Beddie with the V6 / T700 auto, I have the standard diff Duel wheels model, I'ts a 4.1 and the van runs great. around town. open road, and with weight behind it, not sure if I would want to change it, but haven't been on any long trips, so that's another question........... but do have a 3.5 I will  try out .
When I first got the van it reved so high in first gear before it would change, It had a loud noise in the back, thought diff. Ended up with a  reo auto and all sweet, no noise in tne back anymore, no revs on changing geras.
Re: Drive line SOS
« Reply #46 on: February 10, 2011, 06:14:17 PM »
I phoned around today, seems 3.45:1 is a common ratio but they only had one there with noisey bearings - for $150, so will keep looking
Re: Drive line SOS
« Reply #47 on: February 10, 2011, 07:38:17 PM »
David, what about your old Cresta Head you had in ther, 3.7 - 3.9?
Offline Hippo
Re: Drive line SOS
« Reply #48 on: February 10, 2011, 09:06:30 PM »
Baz,
How many RPM at 100km in 4th please. I have a ls1 gen3 and 4l60e to put in my(soon to be picked up) LWB dual wheel Winnebago type camper
which I assume also has the 4.1 diff. Are your front wheels std 6 stud and 15".What size are the rears please. Do I see that you still have the drum brake front end?.
Dennis
Re: Drive line SOS
« Reply #49 on: February 11, 2011, 06:01:38 AM »
Baz,
Dennis
just letting you know most of the orig diffs ive seeen in lwb are 5.2:1  :(
