  • Dot Guests: 1449
Author Topic: Drive line SOS  (Read 29914 times)
Offline Rocket
Re: Drive line SOS
« Reply #10 on: October 20, 2010, 06:56:36 AM »
In reverse the load switches from one engine mount to the other. I know this for certain because up to date I have broken 6 mounts (to much throttle --350 chev). My motor tried to climb out of the engine bay when the one affecting reverse broke.
Rocket
Nothing on a Bedford is reliable--until it's modified
Re: Drive line SOS
« Reply #11 on: October 20, 2010, 08:37:58 AM »
Ok I had something like this happen on my, dare I say it, V6 Transit, turned out to be one of the springs on the pressure plate.. and for  some reason it only happed in reverse
Offline Jeff
Re: Drive line SOS
« Reply #12 on: October 20, 2010, 02:31:21 PM »
Rocket
Well, I  take your word for it, and Ben's, but I still can't see that.
I'll work on it. ....LOL.
Edit.... Yep. Apologies. I can see it now.  Thanks.
« Last Edit: October 21, 2010, 03:57:23 PM by Jeff »
Funny old life.
Re: Drive line SOS
« Reply #13 on: October 20, 2010, 06:13:34 PM »
ditto Rocket, had the same malfunction with a chev motor in one of my earlier beddies, showed all the same indicaters couldn't work it out till I lifted the engine cover and tryed it in reverse, motor tried to climb into the cab ..... broken engine mount >:(
Offline LS120
Re: Drive line SOS
« Reply #14 on: October 21, 2010, 04:37:50 AM »
well have had it to the doctors & have found the problem............... :'(
it's the pinion shaft bearings failing & the bearings are $400 each ex-germany...
so gonig to get a ford/holden centre put in & driveshaft done as well....
for the same money as trying to fix the old cresta setup.
oh well it seems my pockets needs to bleed money at this stage...
($800)
thanks for your help guys
Offline Jeff
Re: Drive line SOS
« Reply #15 on: October 21, 2010, 05:39:25 AM »
 :o
I recently replaced all the bearings in my Cresta diff for less than $400, ex Wellington.
I *think* the pinion bearings would be the same.
I did buy them wholesale, but could probably do so again.
We need to get together.
« Last Edit: October 21, 2010, 05:44:40 AM by Jeff »
Funny old life.
Re: Drive line SOS
« Reply #16 on: October 21, 2010, 05:48:23 AM »
$800 for new center put in and driveshaft ?
Re: Drive line SOS
« Reply #17 on: October 22, 2010, 07:55:00 PM »
800 sounds really cheap
Re: Drive line SOS
« Reply #18 on: October 23, 2010, 06:53:57 AM »
I reckon ben, the crowd up here wanted $500 just for a driveshaft to be done
Offline LS120
Re: Drive line SOS
« Reply #19 on: October 25, 2010, 06:42:55 AM »
yea.. a drive shaft was about $185-195.00 chop & re-balance... the rest is to take out the onld insides & redo it with a late modle holden or ford insides (banjo style) so you can change the ratio easy. and incl labour to do it.
so $800 is not too bad... but still hurts the pocket..
