  • Dot Guests: 461
Author Topic: cf1 vs cf2 doors  (Read 12300 times)
Offline erics8
cf1 vs cf2 doors
« on: September 29, 2010, 01:21:59 PM »
Hi all, ive come across a couple of sadly deceased bedfords lately, both cf1's, will cf1 cab doors fit a cf2?
Cheers!  :)
Re: cf1 vs cf2 doors
« Reply #1 on: September 29, 2010, 01:34:58 PM »
To my knowledge you should be fine. I think the internal door handle fittings are different as are the mountings for them and a couple of other cosmetic things like the door lock knobs and window winder handle but as far as the hinges and actual steel work is concerned I think you're ok.
« Reply #2 on: September 29, 2010, 06:01:15 PM »
they are interchangable but as Rogue pointed out there are a few minor differences
The biggest being the inside door handle section, the early mk1 has a raised section across the door where as the mk2 doors are flat. The real early mk1 doors didnt have door panels, just a little plate around the inner door hanlde, but the later ones did. The door panels wont swap over very tidy.
hinges, catches, windows and regs etc are all the same
and both version rust in the same places :rolleyes:
« Reply #3 on: September 29, 2010, 07:04:38 PM »
Sorry Guys, have to disagree, the doors do fit, but the door line though the middle is different, as you know  (well most) I changed to a Mk 2 front on my Mk 1 beddie and wanted to keep the Mk 1 doors due to the conditionn of them, but line was not the same, can't remember what it was, but as far as fitting no problems. Might pay you to check it out.
Offline LS120
« Reply #4 on: September 30, 2010, 04:44:12 AM »
on the inside the door opener is diffrent too.. the older cf1 was a pull up or push down type & the later was a pull out style.
« Reply #5 on: September 30, 2010, 06:01:58 AM »
Bas, I got mk2 doors on my standard (mk1) CF, lines are good
« Reply #6 on: September 30, 2010, 06:11:44 AM »
Ok David, sorry about that guys, I was sure it was different, must of been another reason why I changed. :)
« Reply #7 on: September 30, 2010, 06:17:36 AM »
Phew, thank god for that. I thought I was wrong....again!  ;D
Offline erics8
« Reply #8 on: September 30, 2010, 02:51:14 PM »
cheers guys, good to know, i wont be keeping my ratty door cards anyway so shudnt b a worry  ;D
« Reply #9 on: September 30, 2010, 05:24:49 PM »
You have a right to be wrong, as you are a Bedford owner, still think it was the line... ;D
