  • Dot Guests: 442
Author Topic: I need a diff housing  (Read 19969 times)
Offline shaginwagin
  • Real Vans are BIG Vans
Re: I need a diff housing
« Reply #10 on: October 03, 2010, 10:48:10 PM »
Thanks to Weasil picked up the beddie diff, today in the back of the Viva, yes it did fit in the boot and back seat down almost into the passenger seat  :). Didn't realise how heavy they were until I managed to get it out of the car. ;D
Warren  yes have 2 VN disc brake diffs, take the short side tube out, replace it with the long tube out of 2nd diff, Thats the bit for the diff man to fix it in the correct position. The next bit  will be cutting about 1 inch off the axle to make it fit.  then get a new axle made up so that the splines are long enough to sit far enough into the gears so they dont brake. It then brings the diff back to within about 1 and half inches of standard beddy track. Using the VN front discs instead of HQ because they are about a bee's dick different stud pattern. All the above will be minor  ::) ::) ::) problems that can be fixed
Shane  yes I do have the VN fuel tank that will go into the beddy, fuel pump inside fuel tank need that or the car wont go fuel injected.
Julian
« Reply #11 on: October 04, 2010, 06:12:24 AM »
www.gmh-torana.com.au/
ronaldoredsox, on May 11 2008, 01:05 PM, said:
I believe the hq stud pattern is imperial and Commodore is metric. The difference is very slight, but, it is real and the two are not interchangable. Someone may need to confirm my thinking. R
Commodore...120mm
HQ...120.65mm...
Dont mix them..the studs break..ugly..
R
http://holdenpaedia.oldholden.com/Stud_Patterns
Commodores use a 5 on 120 mm (4.724") PCD. Very close to the HQ - WB PCD but not close enough. If you put Commodore wheels on an old Holden (or vice versa), you will break your studs and be overtaken by your own wheel...not a good look.
quotes pulled from other forums with discussion on this topic
i have also had personal experience with breaking wheel studs because of this little issue and its not a good feeling.
just warning you.
« Last Edit: October 04, 2010, 06:21:37 AM by ben »
« Reply #12 on: October 04, 2010, 11:27:59 AM »
Agree Ben
Ive had the same thing - but on the bright side Mr SW could use rims suitable for commodores, go to larger diameter rims and have a better selection of tires to choose from.
I'm pretty sure he was going commode on the front as well.
« Reply #13 on: October 04, 2010, 09:16:20 PM »
oh sorry i got the impression he was still running his hq wheels.
Offline jesus_is_alright
« Reply #14 on: October 05, 2010, 09:22:51 AM »
the funny thing is that although the difference between hq (4.75") and commodore (120mm) is less than 1mm, it will break studs,
they used to make mags with uni-lug
http://www.roadsters.com/E-T_III_500x492.jpg
these oval shaped holes could fit say ford (4.5") to drag (5") and anything in between (chev/hq 4.75")
on a side note, does anyone know the PCD of the current falcons?
-Aaron
« Reply #15 on: October 05, 2010, 10:29:11 AM »
Should still be 5x114.3
« Reply #16 on: October 05, 2010, 11:54:35 AM »
hmm, still 4.5" interesting. Why not change to metric like commodores?
-Aaron
« Reply #17 on: October 05, 2010, 11:55:18 AM »
..... Using the VN front discs instead of HQ because they are about a bee's dick different stud pattern. All the above will be minor  ::) ::) ::) problems that can be fixed
Ben
from the above I take it that Julian will have VN front and rear, if thats so then using commadore/accessory wheels to suit would be the better way to go, as I said most likely a better choice of rims and tyres that way.
I also think a lot of other cars have the same stud pattern - BMW,  Volvo  Range rover etc - might find some flash stock wheels cheap.
« Reply #18 on: October 05, 2010, 07:25:31 PM »
It is metric. Its 114.3mm
Offline shaginwagin
« Reply #19 on: October 05, 2010, 11:07:05 PM »
Yes using VN discs front and rear, haven't had a look yet but the calipre bracket should be the same but if not will make new ones.  Probably easier to make some new ones anyway, got the pattern for the calipres easy to make anyway.
Julian
