  • Dot Guests: 830
Author Topic: Dynamat Group buy or single buy  (Read 35234 times)
Re: Dynamat Group buy or single buy
« Reply #30 on: August 07, 2010, 09:07:37 AM »
Thanks guys, the one thing i found with a lot of of the people i spoke to, for some reason they did not want to give out their suppliers, weird mob. I am considering doing my cab interior mostly in fibreglass. That way i can  get the shapes and design i want.
« Reply #31 on: August 07, 2010, 09:59:47 AM »
There are a number of other ways of doing this. Complicated large shapes can be done by forming the basic shape in mdf, covering with speaker cloth then fibreglassing the cloth, and bogging it from there.
you dont have to buy speaker cloth.. for big shapes dunk a bed sheet in resin or any material lay it over the basic shape you made when it goes off you can bog and either make a mould from it or just paint.
i have a fibreglass article in pdf file. how do i post it on here?
« Reply #32 on: August 07, 2010, 10:17:12 AM »
Send it to Shane via admin@buga.com.au and he'll stick it in the downloads section under Technical.
« Reply #33 on: August 07, 2010, 10:18:26 AM »
Ben you use your hand and keyboard and it helps to have your computer on as well. ;D or post it to buga.com.au:D
« Last Edit: August 07, 2010, 10:20:53 AM by Bas NZ »
« Reply #34 on: August 07, 2010, 10:21:22 AM »
ha ha good one bas.
ok will do rouge. got heaps of tech articles in pdf form you guys will love em.
« Reply #35 on: August 07, 2010, 03:46:25 PM »
hey guys, for years now i have been looking for a company the does spray foam insulation, i was looking for someone to do my house, but anyhow does anyone here know of anyone that does it, i was thinking of doing the van, could you spray it in the back of the van and then trim it back to the ribs to give it a clean look. Would the spray foam sound & weather proof your van. Then just trim over the top with the final finish. I am just exploring all options b4 i spend money. Would appreciate views from here.
« Reply #36 on: August 07, 2010, 05:04:03 PM »
wanna do good rust proofing first george. spray foam.
Offline grandad
« Reply #37 on: August 07, 2010, 05:25:39 PM »
yep spray foam on steel = rust
« Reply #38 on: August 07, 2010, 07:00:04 PM »
yeah ur not wrong there grandad
yep spray foam on steel = rust (holds water and moisture against steel for longer period instead of draining awayl)
« Reply #39 on: August 08, 2010, 09:38:53 AM »
OK, no spray foam. lol thanks for the advice guys.
