  • Dot Guests: 424
Author Topic: Tie rod Q  (Read 8394 times)
Offline Sweet Shock
Re: Tie rod Q
« Reply #10 on: July 10, 2010, 07:31:24 PM »
Heres a pic of the right side, and im using gimp thanx to whoever put the link up
Offline Sweet Shock
Re: Tie rod Q
« Reply #11 on: July 10, 2010, 07:38:42 PM »
Tommaroe ill have a better look and see what the difference is between right and left, The right side is fine and i always have trouble spelling tommoroe its just one of those words i have spelling also cheak and check, anyhow thax fellers  pete
Re: Tie rod Q
« Reply #12 on: July 11, 2010, 11:24:02 AM »
as Rouge said, I too had to grind just enough for them to clear.....doesn't take much ;)
Offline Sweet Shock
Re: Tie rod Q
« Reply #13 on: July 11, 2010, 02:16:15 PM »
Well I had a good look today, The right side is flush and as you can see, the left needs to be grounded, I was told it was the tie rod, I should have had a good look myself my bad , anyhow another thing fixed, thanking you heaps, Now ill focus on a legal exhaust
Re: Tie rod Q
« Reply #14 on: July 11, 2010, 02:24:40 PM »
i think.................this is what happens with crs orig kits.. the caliper fouls.. they then made a second type that doesnt foul........ i think.
