  • Dot Guests: 1048
Author Topic: mirrors ???  (Read 13674 times)
Re: mirrors ???
« Reply #10 on: June 09, 2010, 10:42:28 AM »
Umm, I looked and there are two pictures that show the mirrors (full van pics) and the mirrors in both are the factory ones.  ;D
I used Eddys pic as it was a close up and shows the general idea of how the Patrol ones would fit.
* Just remebered - I think Eddys are of a Navara, he had to grind a edge off the L shaped base to get it to sit flat, the navara sit on the 90 degree edge of the gaurd.
bradford
Re: mirrors ???
« Reply #11 on: June 09, 2010, 10:51:11 AM »
cheers guys, anyone know what model/ year patrol mirrors are on rothu's van. im struggling to locate them at wreckers or ebay
Re: mirrors ???
« Reply #12 on: June 09, 2010, 11:18:03 AM »
The other day i was sitting at a shopping centre carpark and beside me was a new Holden "Captiva" 4wd. and the mirrors looked like a viable option to stick on a beddie. Ill see if i can find a pic. ;)
« Last Edit: June 09, 2010, 11:24:36 AM by John Abbott »
Re: mirrors ???
« Reply #13 on: June 09, 2010, 12:28:23 PM »
The square ones - late eighties to ninty I think
what about These
« Last Edit: June 09, 2010, 12:31:18 PM by Warren »
Re: mirrors ???
« Reply #14 on: June 09, 2010, 07:06:54 PM »
I'm using some toyota people mover ones that sound very similar
here is a pic from the mounting point  -  http://www.tradenote.net/images/users/000/102/933/products_images/Isuzu_Pick_Compatible_Rearview_Mirror.jpg
and its of this or similar - http://www.nordstromsauto.com/CARPHOTOS/1/TJ8758-1.jpg   these come out in 3 styles - manual, electric plain and electric fold in
« Last Edit: June 09, 2010, 07:23:15 PM by BusyKiwi »
bradford
Re: mirrors ???
« Reply #15 on: June 10, 2010, 10:06:12 AM »
im leaning towards the navara mirrors, thanks 4 the pics and info guys. i gather i'll have to drill at least 1 more hole in the door to mount it. is it alright to screw into new hole without there being any thread inside door like the original threads
Re: mirrors ???
« Reply #16 on: June 10, 2010, 10:12:23 AM »
It shouldn't be a problem to screw into the door - after all beddies are made of real steel :D
If you can re use the top two, if not all three could be drilled into the sheet metal, just make sure you use the appropriate sized drill for the screws you use.
Re: mirrors ???
« Reply #17 on: June 10, 2010, 10:18:32 AM »
Just reach your hand up inside the door and put a large washer and nyloc nut on the other side of the mounting bolt. It's not like you can't get to the other side of the door panel easily. probably easier with 2 people though as you'll have to have the window up unless you have really long arms.
Re: mirrors ???
« Reply #18 on: June 21, 2010, 09:08:01 AM »
Go to a Truckline Branch and have a look at their Britax mirror catalogue
Petrolhead
Re: mirrors ???
« Reply #19 on: June 21, 2010, 06:19:26 PM »
Or see them on their webpage: http://www.britaxae.com.au/mirrors.php
The 4003-161 looks like it might just bolt on. Down the bottom of: http://www.britaxae.com.au/products.php?categoryname=1+Pce+Door+Mount%2C+4WD&subcategoryid=2&page=1
