  • Dot Guests: 1280
Author Topic: Mezz's Beddie Update  (Read 60450 times)
Re: Mezz's Beddie Update
« Reply #140 on: August 26, 2010, 05:06:46 PM »
Do me a favour - if you succeed, can you give her a good wash for me!!!
« Reply #141 on: August 26, 2010, 06:50:18 PM »
congrats on job well done
« Reply #142 on: August 26, 2010, 07:07:53 PM »
Hey mezzmo, some questions for ya.
Are you running HQ disks with CF booster?
Were did you mount your air intake box, did you use the commodore one?
accelerator cable, get one made up or found one that fitted?
« Reply #143 on: August 26, 2010, 07:28:35 PM »
done deal.......cause we are both very stealthy in stature.....no one will notice us!!!!!
hahahaha
« Reply #144 on: August 26, 2010, 08:44:20 PM »
Hi Busy,
Running the standard booster with the hq discs but after the bash we are going to look for a different booster to give us a bit firmer pedal, it does the job but it could definitely be better. The air intake box is mounted directly behind the bonnet scoop and is the original commodore one - using the original filters. Worked like a charm. As far as the accelerator cable, i am positive that the mechs had a new one made, i can check this out for you when i next talk to them.
When the van gets back i'll take some close ups of the air intake if you like.
« Reply #145 on: August 27, 2010, 07:23:06 AM »
Thanks that will be good, I've mounted my intake box under the booster and my radiator is a bit higher so is very tight for all the pipe work
« Reply #146 on: August 27, 2010, 04:13:59 PM »
We found that because the V6 sits so low, we had a shitload of room between the top of the engine and the underside of the bonnet, what are you running Busy?
« Reply #147 on: August 27, 2010, 07:16:00 PM »
same as you, the 3.8 VN series one engine - in the standard CF
Offline kimbosound
« Reply #148 on: August 27, 2010, 11:37:39 PM »
there is a photo of the back of Mezz'z beddy in the local albany paper.....i will try to take a pic and post it soon
« Last Edit: August 27, 2010, 11:43:41 PM by kimbosound »
« Reply #149 on: August 28, 2010, 10:23:51 AM »
Hey Kimbo, is there any chance i can get you to get me some copies? that would be awesome. i can PM you with my details.
Mezzmo
