  • Dot Guests: 706
Author Topic: seat bases  (Read 14652 times)
Offline Sweet Shock
seat bases
« on: March 04, 2010, 12:15:55 PM »
Would any body have any seat bases in victoria, Mine are cracked,thanks pete
Offline neville668bartos
Re: seat bases
« Reply #1 on: March 04, 2010, 05:20:14 PM »
to be honest i'd think you'd find most bases are!!!! probably better of welding some new frames up?
Offline Sweet Shock
Re: seat bases
« Reply #2 on: March 04, 2010, 07:27:17 PM »
Yea thanks but would an engineer pass it, any ideas anyone thanks pete
Re: seat bases
« Reply #3 on: March 04, 2010, 07:48:18 PM »
nev might be right, weld it, grind it, paint it and if need be drace it on the in side with a bit of strap
Offline jimsvan
Re: seat bases
« Reply #4 on: March 04, 2010, 07:52:38 PM »
im buying a van for parts for my van im in melb
Re: seat bases
« Reply #5 on: March 04, 2010, 09:01:30 PM »
Hey GG do you have a MIG or Oxy ??
The seat bases crack in certain places (usually around the mounting bolts) so I would suggest repairing the base and then reinforcing it with 20x3mm flat steel on both the top and bottom edges.
The flat steel coul possibly be welded on the iside of the bases, hiding it even further.
A lot of the damage to the bases is done by the base stretching around the bolt area (which is sheet steel), the thicker material spreads the load over a greater surface area dramaticly reducing the likelyhood of any further cracking.
All the repairs could be done for very little cash and a bit of time.
Re: seat bases
« Reply #6 on: March 04, 2010, 09:04:38 PM »
Just to add, I think that the steel required to make a new base has to be 25x25x3 mm tubing.
Check the ADRs
Re: seat bases
« Reply #7 on: March 04, 2010, 10:09:30 PM »
another thought..
early models came with the bases welded to the floor. they were welded on the inside and out. about 4, 1 inch long welds outside and 4 inside too.
if you cant be bothered repairing you could always just weld them to the floor like i usually do. sorry furio..
i find is quicker than stuffing around with bolts and all that. just not so easy to take out. but how oftern do you plan on taking your beddy seat bases out anyway???
just ideas..
Re: seat bases
« Reply #8 on: March 05, 2010, 11:53:20 AM »
I was having a look at mine yesterday, and they are welded in like Ben said. Mine is a 1975 truck.
Offline beddymad
  • new project
Re: seat bases
« Reply #9 on: March 05, 2010, 03:38:21 PM »
tell me about it ben.it  took me about an hour to remove the seat base lol.great work ben ;D
